Activity › Forums › Adobe After Effects › Auto-trace layer problem
  • Auto-trace layer problem
    Posted by S. Marcotte on October 3, 2007 at 2:30 pm
    I’m trying to auto-trace alpha after a quick key. It looks good in the preview, and every frame gets processes, but the result is an empty layer in the timeline. There’s a new solid in the project window, but when dragged to the timeline this solid shows nothing either.
    Vague, I know.
    Erik Pontius replied 19 years ago 2 Members · 2 Replies
  • S. Marcotte
    October 3, 2007 at 4:58 pm
    I did set for apply to new layer. I’ve done this before without a hitch. Feels like a glitch. I get some pretty funky results when don’t apply to new layer as well. Might be time for a reinstall.
    I’ve done that tutorial. It’s a good one.
  • Erik Pontius
    October 3, 2007 at 7:42 pm
    When auto-tracing and applying to a new layer, the new layer should appear directly above the layer you are auto-tracing when it is finished. Select the layer and hit M, you should see all the masks it has created based on your auto-trace.
    I’ve also seen strange problems happen with auto-trace when only using a portion of a clip, say a 3 minute clip and you’ve trimmed it to one minute. Auto-tracing the entire clip, then pre-comping and trimming that seems to work.
    Erik
