Activity › Forums › Avid Media Composer › Auto Sync, Missing Waveform
  • Michael Phillips
    April 3, 2015 at 5:08 pm
    Are you saying you can’t see the waveforms on the newly created .sync clips? In the source monitor or record monitor? What version and OS?
    Michael
  • Ben Northenor
    April 3, 2015 at 5:27 pm
    Correct. I can’t see the waveform in the newly .sync clip in my Record Monitor. I’m on version 6.5.4.4 and the OS is 10.8.5
    http://www.bennorthenor.com
  • Michael Phillips
    April 3, 2015 at 7:16 pm
    Can you see them in the source monitor when switching the timeline view to source monitor and enabling waveforms there? And can you see them on the original source files before syncing them?
  • Ben Northenor
    April 3, 2015 at 7:19 pm
    I can on both. I exported the AIFF file to a .wav file from iTunes, but that still didn’t help. I’m very confused.
  • Michael Phillips
    April 3, 2015 at 9:26 pm
    Does the sample rate and bit depth differ from the project setting by chance? It does seem strange that you can see it on the clip before syncing. You might need to clear the waveform cache and see of that clears it up for you after it rebuilds.
    In the project folder, there is a folder called WaveformCache. Delete its contents. Relaunch and wait a bit while they rebuild and see if that fixes it.
    Michael
  • Ben Northenor
    April 3, 2015 at 9:51 pm
    I can’t find any WaveformCache files in my project file.
  • Michael Phillips
    April 3, 2015 at 10:08 pm
    Right… cached waveforms was part of the 7.x release. I’m stumped at this point.
    Michael
  • Ben Northenor
    April 4, 2015 at 12:51 am
    I feel the same way. Thanks for trying.
