Activity › Forums › Adobe After Effects Expressions › Auto-sized box under your text. How to control the width and height of that box?
  • Auto-sized box under your text. How to control the width and height of that box?
    Posted by Joel Arvidsson on August 6, 2017 at 3:47 pm
    Im doing a motion graphic template in after effect to use in premiere. The goal is to make text with an autoscaling box under it.
    While I found a couple of tutorials on how do this but I wish to be able to control the height and width of the backround box separately. I have tried the offset path inside of the shapelier (the background box) and it would worked perfect if only you could scale x and y separately.
    But all my attempts have failed.
    I was hoping the offset path in the shape layer would do the trick but it only scales uniformly on x and y.
    joelarvidsson@gmail.com
    Joel Arvidsson replied 9 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    August 6, 2017 at 6:43 pm
    If you’re using a rectangle shape, you adjust x and y of the path Size parameter separately.
    Dan
  • Joel Arvidsson
    August 6, 2017 at 9:05 pm
    I tried that but it seams to offset the bg rectangle when typing. This is due to the expressions that scales the bg rectangle based on the characters.
