Activity › Forums › Apple Final Cut Pro › Auto Save Killing Me
  • Auto Save Killing Me
    Posted by Sterling Noren on August 29, 2014 at 6:01 pm
    Hi all,
    About every 10 minutes or so my Final Curt X program begins “backing up” (according to the Background Tasks wind). I have a fairly large project, it usually takes about 30 seconds for it to complete this automatic function. During this time, system responsiveness slows to a crawl – basically no editing for the duration. Since this happens every ten minutes or so, it is a real buzz-kill to productivity.
    Is this normal? Is there any way to turn off this auto-save function or at leaf set it to occur less often?
    James Ewart replied 12 years ago 10 Members · 13 Replies
  • 13 Replies
  • Noah Kadner
    August 29, 2014 at 6:14 pm
    Is your system drive designated as the backups drive- is it close to full?
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Charlie Austin
    August 29, 2014 at 6:38 pm
    [Sterling Noren] “Is this normal? Is there any way to turn off this auto-save function or at leaf set it to occur less often?”
    You can turn it off. Select the Library, open the inspector, click the “modify settings” button next to Storage Locations, click the Backups drop down and choose “Do Not Save’. If you do this, I’d strongly recommend using Backups for Final Cut Pro (app store) or something. Having no backups is a very bad idea. I use Backups, as well as Digital Rebellion Pro Versioner. More is better. 🙂
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Bret Williams
    August 30, 2014 at 4:40 am
    Careful now, Bill might accuse you of slandering the good name of Final Cut Pro by accusing it of murder! 🙂
  • Robin S. kurz
    August 30, 2014 at 3:53 pm
    Odd. I even have mine set to backup to the cloud and a lot of large projects open (though the amount of data per backup cycle is in fact *very* small) and I never notice it. I would assume there may be an issue with the disk you are saving to.
  • Claude Lyneis
    August 30, 2014 at 4:15 pm
    I assume you don’t have Tima Machine on. That gave me trouble, long ago.
  • Bill Davis
    August 30, 2014 at 4:33 pm
    Not might, Bret, would.
    Remember, I came our of advertising. There’s nothing more powerful than unaddressed slander when it comes to moulding public opinion.
    Just remember how John Kerry, the one who served honorably in combat in Vietnam – got “swift boated” into being “the coward.” And how Bush 43 (who had kinda sorta draft-dodged via a preferential Nat Guard slot) got painted as the brave patriot in the 2004 election cycle?
    Regardless of the esteem or contempt which which you hold either participant, there’s never been a clearer example of how allowing inaccurate messaging to go unaddressed can mould public opinion away from truth and elevate the stature of lies via message manipulation.
    So yep, I push back. And am delighted when others counter-push and that leads to the clarity of robust discussion.
    That’s just how I’m wired. ; )
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • Mark Smith
    August 30, 2014 at 5:04 pm
    are you backing up the ptroject and the media, or just the project? If you are backing up project and media, I can see why things would grind to a halt on back up.
  • Robin S. kurz
    August 30, 2014 at 5:23 pm
    [Mark Smith] “are you backing up the ptroject and the media, or just the project?”
    FCP X’s backup feature does not backup media.
  • Mark Smith
    August 30, 2014 at 7:55 pm
    Why did I think that backing up media was an option? Has it been an option in the past?
  • Bret Williams
    August 31, 2014 at 3:12 am
    Backing up at all is a new feature. So no it wasn’t an option in the past. A decent idea, but a good Raid 5 probably addresses large amounts if data better than a background backup.
