Activity › Forums › Apple Final Cut Pro Legacy › auto save general error
Posted by Torrey Harris on July 23, 2007 at 2:43 pmi have my auto save set to every 5 minutes well every 5 minutes it tells me that
AUTO SAVE : general error
help does anybody know how to fix this problem
Torrey
1-225-315-6677Ben Holmes replied 19 years, 2 months ago 2 Members · 3 Replies -
Ben Holmes
July 23, 2007 at 4:28 pmWhat happens if you try to save manually? If that seems to work, check your autosave settings.
If it doesn’t work, you may an issue with the project, which may require reverting to a previous version. Let us know how you get on with the manual save.
Ben
Editec Broadcast Editing Ltd
EVS & FCP specialists for live broadcast.
OB Server 1 HD – Mobile FCP editing done right.
https://www.editecuk.com/OBServer2.html -
Torrey Harris
July 23, 2007 at 4:53 pmmanually i can save but i’ve checked al my settings for user prefrence and they match up with another machine i have that i use as a second suite and both settings are exactly the same,
do u think it maybe from a corrupted file or my project is corrupted
torrey
Ben Holmes
July 23, 2007 at 9:09 pmI was wondering if your autosave location was valid, especially if the settings were ported from another machine. I know it’s a long shot, but the folder still exists – you can browse to it?
Usually this kind of error suggests project corruption, or if it happens during opening, a corrupted media/render file. On autosave, it sounds more like a ‘trash prefs’ kind of error. I would suggest saving the project under another name, and seeing if you can open it ok whilst fcp is still running. If so, trash prefs and the issue may well disappear. Oh, and repair those permissions too!
Ben
