Activity Forums Adobe After Effects Expressions Auto position animation at the end of the composition
  • Auto position animation at the end of the composition
    Posted by Avinash Ramanath on May 2, 2017 at 10:27 am
    I have many placeholders inside render comp. placeholders duration will be different for each placeholder. I want an expression that will automatically move the position of placeholders from [960,540] to [960,-540] in the last 20 frames of the placeholder comp.
    Avinash Ramanath replied 9 years, 4 months ago 2 Members · 17 Replies
  • 17 Replies
  • Steve Sierra
    May 2, 2017 at 11:48 am
    Hi again,
    I think you could put this in the placeholders’ positions :
    m = timeToFrames(thisLayer.source.duration) + timeToFrames(thisLayer.inPoint) – 20;
    n = framesToTime(m);
    p = framesToTime(20);
    y = ease(time ,n, n+p, [960, 540], [960, -540]);
    if(time>n){
    y
    }else{
    [960,540];
    Cheers !
  • Avinash Ramanath
    May 2, 2017 at 2:37 pm
    Thanks Steve, that worked
  • Avinash Ramanath
    May 4, 2017 at 4:55 am
    Steve, need one more alteration. What should the expression be if it needs to have different in and out animations
    example:
    in – from [960,-540] to [960,540]
    out – from [960,540] to [960,-960]
  • Steve Sierra
    May 4, 2017 at 11:36 am
    I think this is what you need :
    a = thisLayer.inPoint;
    b = timeToFrames(a);
    m = timeToFrames(thisLayer.source.duration) + b – 20;
    x = ease(time ,a, a+p, [960, -540], [960, 540]);
    y = ease(time ,n, n+p, [960, 540], [960, -960]);
    if(time = b){
    x
    }else{
    if(time>n){
    y
    }else{
    [960,540];
    Cheers 😉
  • Avinash Ramanath
    May 4, 2017 at 12:03 pm
    Only out animation is happening, but in animation is not happening.
  • Steve Sierra
    May 4, 2017 at 12:33 pm
    Oups…
    It’s supposed to be :
    if(time = a){
    x
    }else{
    if(time>n){
    y
    }else{
    [960,540];
    I put b in the if condition instead of a… interchanged those varibles at the last minute 😉
  • Avinash Ramanath
    May 4, 2017 at 12:42 pm
    Sorry, Steve, it’s still nor happening.
  • Steve Sierra
    May 4, 2017 at 12:56 pm
    You’re right…
    I don’t know why. I’m only getting the In animation.
    I’ll lokk into it when I have some time, unless someone else helps you out.
    Good luck !
  • Avinash Ramanath
    May 4, 2017 at 1:03 pm
    Appreciate it thanks.
  • Steve Sierra
    May 4, 2017 at 1:05 pm
    I think I got it :
    b = timeToFrames(thisLayer.inPoint);
    m = timeToFrames(thisLayer.source.duration) +timeToFrames(thisLayer.inPoint) – 20;
    if(time n){y}
    Cheers !
