Activity › Forums › DaVinci Resolve › Auto Masking of static clip using a shot of it empty
  • John Fishback
    October 10, 2024 at 8:25 pm
    The Magic Mask will probably work for this if you have the Studio Version. Here’s a link to a tutorial.
    https://youtu.be/HAlfApCFQwI
  • Andrew Shtern
    October 11, 2024 at 9:51 am
    Try to use a difference keyer in Fusion. You need to denoise your footage before keying, and you can combine it with the magic mask for better results. You probably will need some roto anyway, but mostly for the garbage mattes.
  • Uli Plank
    October 22, 2024 at 1:02 pm
    I was never too happy with the results of a. difference map.
    But since DR is pretty good at tracking a Power Window, you could just stack the other clips, give each one an alpha output and use such a window for the person, with a soft edge to hide it.
