Activity Forums Storage & Archiving Auto connect NAS shares at starup macos Big Sur
  • Auto connect NAS shares at starup macos Big Sur
    Posted by Armin Vasilico on July 21, 2021 at 1:49 pm
    The situation:
    I run a Qnap NAS as a file server in my office environment. The NAS and all iMacs are connected to a Gigabit-Switch. To automatically connect network drives from the NAS at startup of an iMac I added the shared folder to “Startup-Items” in the user accounts.
    The problem:
    If the NAS is in standby mode when a user logs in, the connection attemp times out before the NAS can leave standby mode and an error message pops up stating the “Server is unavailable”.
    But the NAS actually is available a couple of seconds later. It just needs a moment to spin up the drives.
    Is there a possibility (terminal commandg or GUI) to set a longer timeout for macos to connect to a network share?
    John Perez replied 5 years ago 2 Members · 1 Reply
  • John Perez
    August 27, 2021 at 9:33 pm
    I’m having a similar problem auto-mounting. GB Labs Space NAS, works fine on Catalina but Big Sur won’t auto mount the NAS after a restart. It mounts fine if you mount it ‘manually’ though…could this be a Big Sur bug?
