Activity Forums Adobe After Effects auto center anchor point?
  • auto center anchor point?
    Posted by Aaron Neitz on March 4, 2008 at 12:58 am
    sorry if this is an obvious problem: I have a bunch of text layers, I want AE to auto center my anchor point on the layers.
    CS3 on a Mac
    thanks!
    Frank Bueno replied 9 years, 6 months ago 14 Members · 15 Replies
  • 15 Replies
  • Jack Watts
    March 4, 2008 at 1:17 am
    You need to activate the “pan behind tool”. You can do this by pressing “y” on your Keyboard and then manually move the anchor point to the centre of your layer.Remember all animations applied to the layer will animate from the anchor point such as scaling,tracking etc.
    For a full list of Keyboard shortcuts see keyboard shortcuts under the help menu within AE or just click on the following link
    Keyboard Shortcuts
  • Darby Edelen
    March 4, 2008 at 1:33 am
    To my knowledge there isn’t an easy way to center the anchor point vertically on the text. The way to do it horizontally is to go to the Paragraph panel and choose to center align the text.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Kevin Camp
    March 4, 2008 at 12:58 pm
    and if you want to center the anchor point vertically with the text, you’ll need to adjust the ‘baseline’ in the character palette.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Franco Andrade
    September 15, 2009 at 10:37 pm
    Is there a way, a script, plugin, whatever, to align automatically to the center of the object?
  • Matt Reyer
    March 29, 2010 at 12:25 am
    To reset the anchor point to its default location in the layer, Alt-double-click (Windows) or Option-double-click (Mac OS) the Pan Behind tool button.
  • Juan martín Fourcaud
    March 27, 2014 at 6:14 am
    And for Auto center the anchor point on a Layer, is Ctrl-double-click (Windows) or Cmd-double-click (Mac OS) the Pan Behind tool button.
  • Mike Mairs
    March 2, 2015 at 11:03 am
    Fast solution – 4s
    Centering anchor inside textlayer
    • Click Pan Behind Tool: shortcut (y)
    • Firstly drag anchor around
    • Secondly press STRG and let it snap to the centerpoint
    Centering textlayer inside comp
    • Activate Title/Action Safe whichs brings up a comp-CENTER-Point
    • Click Selection Tool (V)
    • Click on the textlayer in layers palette
    • Drag the textlayer in view window around
    • Press STRG and dock Textlayer-Anchor to comp-CENTER
  • Muhammad Salleh
    November 11, 2015 at 5:23 pm
    its ctrl + alt + home.. for WINDOWS. walllah…
    Only in CS2014 upwards i think.. (notsure)
  • Kevin Reiner
    November 12, 2015 at 3:03 am
    https://aescripts.com/repositionanchorpoint/
    I use this scrip at lease 20 times a day. Very simple but so useful. It moves your anchor point to the middle, the corners, or the sides without messing up your animations.
  • Joseph Simons
    January 9, 2016 at 7:53 pm
    The answer is simpler than all of these responses!
  • Right click on layer, Transform > Center Anchor Point in Layer Content
  • Done!
