Activity Forums Adobe After Effects Auto-bezier?
  • Auto-bezier?
    Posted by Dan_gerous on April 26, 2007 at 10:16 pm
    So I was watching Andrew Kramer’s 2nd light streak tutorial and I noticed that when he created a null object position key frame, moved down the timeline and moved the null object, the null objects path was a curve. Now when I try that, my object moves from point to point to point without a curve between them, it moves along angles not along curves. Is there a setting where you can make auto bezier curves when you move an object?
    Darby Edelen replied 19 years, 5 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 26, 2007 at 11:43 pm
    You probably have ‘Default Spatial Interpolation to Linear’ checked in your General Preferences. If you turn this off then your position/anchor point keyframes will default to auto-bezier.
    I personally don’t like to default to auto-bezier as it often times makes decisions for me that I don’t like. I like to edit the motion path with the pen tool. It works just like masks.
