Activity Forums Apple Final Cut Pro Legacy Auto Adding Chapter Markers
  • Auto Adding Chapter Markers
    Posted by Derek Bowshier on April 27, 2010 at 10:02 pm
    I have an hour+ worth of footage clips of various length that I dropped
    in the timeline to export for the client to preview.
    Is there a way to automatically assign chapter markers at each clip break. There are well over 100 clips and will take too much time to manually add a marker for each one. It seems there should be a way, just not sure how to get there.
    db
    Rob Grauert replied 16 years, 4 months ago 2 Members · 1 Reply
  • Rob Grauert
    April 28, 2010 at 12:20 am
    Not that i know of.
    It doesn’t take that long to add a chapter marker though. When you press the down arrow, it takes the playhead to the next cut. Then Press M to make a marker. Press M again to open the Marker dialog box, then click Add Chapter Marker. Then press Enter/Return. It can be done mostly without the mouse, so it’s not that bad.
    If you ask me, you don’t need to add chapter markers for a client preview. Use a timecode generator
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
