Activity › Forums › Compression Techniques › Authoring Blu-Ray: What to do with 1080p 29.97 footage
  • Authoring Blu-Ray: What to do with 1080p 29.97 footage
    Posted by Brandon Farmahini on September 1, 2012 at 2:07 am
    I have feature movies that are 1080p 29.97fps. Blu-ray however does not support that resolution/frame rate.
    I either have to make it 1080i or 720p 59.94. I don’t know what to do.
    1080i has 1.2 the amount of pixils as 720p but I’m afraid of possible interlacing issues on TVs or monitors.
    Here are my processes for each:
    1080i: Modify my settings in compressor to export upper line (interlaced). Nothing else changes. About a 22 bit rate
    720p: Downscale to 720 with a better resize setting. Convert to 59.94 with a fast frame control setting. Using best for fps creates this really awful smoothing effect like what you see in new LED TVs.
    Does anyone have a recommendation? Either I interlace footage or downscale and double the frame rate.
    Also, bit-rate suggestions?
    Eric Pautsch replied 14 years ago 2 Members · 1 Reply
  • Eric Pautsch
    September 3, 2012 at 8:44 pm
    You have progressive video so just confirm it to 23.98 using a tool like Cinema Tools. Timcodes are just numbers
