Activity › Forums › Adobe Audition › Audition tips on fading
  • Willie Toth
    November 16, 2006 at 1:37 am
    Read up on ENVELOPES in the help file … You can also take the clip you want to fase into the edit side, highlight the length of fade you want and in the favorite menu one of the defaults is fade out, double click on it and you will be good to go ………. WILLIE
