Activity Forums Adobe Audition Audition results clip sibilence, but don’t show on waveform
  • Audition results clip sibilence, but don’t show on waveform
    Posted by David Owen on May 27, 2009 at 12:33 pm
    Whenever I apply multiband compression to a 32-bit voiceover file (edit view), I end up with good audio EXCEPT that the very high frequencies sound clipped. I always take the precaution to normalize to get my peaks below -3dB and the peaks never show as being above it after the process. Yet, the sound “splats” on high frequencies.
    I’m using the on-board audio in conjunction with Matrox RTX2 card. Any ideas on where this is coming from? Is this just a limitation of Audition’s multiband compression?
    Jesse Ruggles replied 17 years, 3 months ago 4 Members · 4 Replies
  • Jesse Ruggles
    May 29, 2009 at 2:15 pm
    What version of Audition/Soundbooth are you using? What are your settings for the multi-band compressor? Do you get the same sibilance clipping if you compress with a single-band compressor? My first inclination is to think that it’s an issue with the settings for the multi-band compressor.
  • David Owen
    May 29, 2009 at 6:22 pm
    Jesse,
    Thanks for your post… I’m using Audition v3. I don’t have “the settings” to offer because each segment I edit comes to me slightly differently. Generally, I don’t crush my audio. I’ll typically boost my high freqs about 6dB and apply a 4:1 ratio at ~-12dB. I watch my band meters to make sure they’re compressing peaks only and I reduce my output gain to ensure I’m not driving above 0.
    My goal is to produce dialog audio with an avg RMS of ~-24dB and peaks around -12dB while creating a crisp, yet clean, result.
    Spot anything in this approach? If not, any other ideas?
    TIA.
    – David
  • Emmett Andrews
    May 30, 2009 at 11:28 pm
    Are you using a professional interface and mic? Compressing will highlight flaws in low-end or consumer gear.
  • Jesse Ruggles
    June 8, 2009 at 6:15 pm
    What frequency range are you boosting in the “highs” and do you EQ pre-comp? Also, are your normalizing your waveforms to a set level (-6db is my preference) before the EQ or comp?
    I’ll be honest I can think of quite a few other things that might play in. Any chance we can hear a clip before and after your processing? Being able to hear it for myself would give me a much greater chance of giving effective advice instead of just more questions.
