Activity Forums Adobe Audition Audition CS6 effects rack peaking?
  • Audition CS6 effects rack peaking?
    Posted by Jeff Dean on April 20, 2015 at 2:37 pm
    A little confused hopefully someone will have the answer.
    Using CS6. Imported sequence from PP into Audition.
    Normalized audio to -6 db. Added a hard limiter at -4db in the effects rack.
    My Meter levels at the bottom of the audition screen are perfect.
    My Meter levels in the effects rack are peaking/going into red.
    Why is the effects rack showing me a different level than the main meters at the bottom – is it just showing me the levels before the hard limiter takes effect?
    Jeff Dean replied 11 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
