Activity Forums Adobe Audition Audition crashes at startup
  • Audition crashes at startup
    Posted by Trainee on May 27, 2007 at 1:24 pm
    I’ve been working with audition for 4 month’s or so, and now all of a sudden it crashes at startup. it seems to load ok, but as soon as the main window opens it gives a popup saying
    “shutting down, to continue working where you left off, restart audition”.
    if you “ok” that, it says
    “runtime error, program :C program files adobe premiere yadayada adobe audition.exe R6025 – pure virtual function call”
    what’s wrong? nothing has changed?
    I installed an ac3 extraction and into wav convertion program, and a FLAC file program. i thought that might be the problem, but uninstalling them didn’t work.
    i tried to repair audition, i’ve reinstalled it, i’ve reinstalled entire adobe, but i get the same result everytime.
    Alan Kelly replied 18 years ago 3 Members · 2 Replies
  • Willie Toth
    May 27, 2007 at 1:45 pm
    What version of Audition are you using? 2.0 can do this and if you are using vista you have double trouble ……….. WILLIE
  • Alan Kelly
    August 20, 2008 at 12:08 pm
    Experiencing similar problem with AA3 startup.
    Tech support for product provided DOS tools to conduct deep uninstall, but this did not resolve problem. Tech support escalation in progress (takes days)
    A particular Windows XP process (Flex?????) is not started.
    AK
