Activity Forums Adobe Audition Audition clips off end of track
  • Audition clips off end of track
    Posted by Chris Figat on April 20, 2006 at 5:43 pm
    Hey guys, designer-type here who’s usually over in the After Effects and Flash forums but my current project has led me to visit y’all.
    I’m doing a Flash project with a voiceover, a narrated presentation sort of thing. Our talent gave us the audio as an MP3 file, and when i brought it into Audition to edit it into the different segments needed I noticed that the last word was clipped off. He’s pronouncing the last digit of a phone number and it cuts off the last tiny bit of “fourteen”, just enough to notice.
    What makes this strange is that when i play the mp3 in iTunes it DOESN’T cut off, it even has a bit of dead space after “fourteen”. It seems that Audition is clipping the track off prematurely for some reason. I did some searching on here and wasn’t able to come up with anything, anyone know what’s happening and how i could fix it? Thanks.
    chris
    i’m not random i’m tangent oriented
    Willie Toth replied 20 years, 2 months ago 3 Members · 5 Replies
  • Chris Figat
    April 20, 2006 at 7:27 pm
    I told iTunes that I wanted it to import files as WAV, which means I could then right-click the file in iTunes and export to WAV. I imported that file into Audition and it was fine, didn’t cut off at the end.
    so apparently the problem is is the way Audition handles mp3’s for future reference.
    chris
  • Steve Parker
    June 30, 2006 at 3:06 pm
    weird…i’m having the same problem, anyone come up with a better solution other than using a wav instead?
  • Willie Toth
    June 30, 2006 at 4:51 pm
    Wave files are the preferred format for Audition, besides why would you want to use a file that is compressed ………. WILLIE
  • Steve Parker
    June 30, 2006 at 4:55 pm
    i was provided with an mp3 file, just working with what was given to me…
  • Willie Toth
    June 30, 2006 at 5:47 pm
    Try to convert it to a wave file and see if that helps ……. WILLIE
