Activity Forums Adobe Audition Audition 44khz but Premiere dv is 48khz
  • Audition 44khz but Premiere dv is 48khz
    Posted by Ragnar on April 22, 2005 at 5:37 pm
    This isn’t a big deal but some insight would be appreciated. It seems to me that all of the loops in Audition are 32 bit 44khz. So, if I create my sound effects and soundtrack stuff there and bring it into Premiere for a dv project, which uses 16bit 48khz, is that any sort of issue at all? I doubt it but want to check with the pros. Or, should I just set up every session as a 16bit 48khz default and go from there? Thanks.
    Ragnar
    Ragnar replied 21 years, 4 months ago 3 Members · 3 Replies
  • Rob Neidig
    April 22, 2005 at 6:12 pm
    Once you have finishded your project in Audition, you should resample it to 16 bit, 48kHz before saving the files to import to Premiere. Otherwise you could end up with files not playing back as they should. I believe Premiere actually does this resampling for you (hence the folder with all the “Conformed audio” clips), but I would do it in Audition first to be sure it sounded like I wanted it.
    Have fun!
    Rob
    Rob Neidig
    R&R Media Producttions
    Eugene, Oregon
  • Willie Toth
    April 22, 2005 at 6:45 pm
    Ragnar,
    You can change the sample rate on the edit side of Audition … P Pro will change it when you render also … WILLIE
  • Ragnar
    April 22, 2005 at 11:35 pm
    Thanks guys. I think I will just go with Audition’s defaults and let Premiere Pro conform it. Happy editing.
    Ragnar
