Audio/Video out of sync on export
I just upgraded and installed Adobe AE CS3. I had been using 7 until recently. Unfortunately for my first project in CS3, After Effects is no cooperating. I have about a 30 second project, that has no video, just still images, and different After Effects layers (solids, text, etc). I also have a .wav file (CS3 does not let you import .mp3’s anymore?) Every time I export the audio and video are out of sync, about 3 seconds or so. When I preview within After Effects, everything is perfect and in sync. Since I installed, I did not tweak any settings, or make any adjustments. Are there any settings I should look at? As far as the exporting goes, I have exported in just about every codec and container type, to confirm that it was not a codec issue. None of them have worked. Any help would be greatly appreciated.
– Charlie
