Activity › Forums › Apple Final Cut Pro Legacy › audio/video link problem
  • audio/video link problem
    Posted by Gunnar Kordestani on March 2, 2008 at 3:16 pm
    I want to trimm (using a ripple edit) in my Timeline (FCP 6.0.2).
    I expect that the Audiotracks of my clip are edited simultaneously
    with the Video (as long as I don’t unlink them).
    But that doesn’t happen. No matter if Video and Audio are linked or not
    only the selected item is affected by any trimming causing either big gaps between the Audioclips or audio and Video going out of sync.
    The exact same thing happens with the blade tool. Only the highlighted
    object is cut into pieces.
    What is the error here? I already tried some checkboxes in the Settings but without any succes.
    Jerry Hofmann replied 18 years, 7 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    March 2, 2008 at 5:06 pm
    Linking has to be turned on for this to work as you’d like. It’s the button that looks like a figure 8 on the top right corner of the timeline window.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Gunnar Kordestani
    March 7, 2008 at 4:04 am
    yes, you are right. Such an easy task. Thank you
  • Ty Ford
    March 7, 2008 at 1:57 pm
    Hi Jerry,
    So in addition to Linking being selected in the menu, the figure eight in the window also has to be selected?
    Why would you have (or use) two linking controls?
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Jerry Hofmann
    March 7, 2008 at 2:44 pm
    They aren’t the same exactly. CMD+L will force a link or defeat a link (the menu item). It’s used to force a link between audio and video where the audio didn’t come from the same clip the video came from.
    Where linked selection (the button or shift+L) will temporarily break a link so you can do things like split edits, or remove video or audio that was linked separately from each other. Then turning it back on will turn the linking back on.
    Jerry
