Activity › Forums › Adobe Audition › Audiomastering of Videofile with varying Audiolevels
  • Audiomastering of Videofile with varying Audiolevels
    Posted by Nils Pokel on December 18, 2006 at 10:29 am
    Hi everyone,
    i have a 100 min video file which was assembled from various pieces of footage with varying audio levels. i do not have access to the initial pieces of footage nor the relating premiere projects but i need a quick (!) way to have all levels roughly the same so there won’t be any signifficant volume changes throughout the film. think of a loooong wave file with inconsistant volume levels.
    is there a tool or filter in audition which could help me on my way, maybe a compressor or some kind of “scenewise normalising”? i wouldnt want to work my way though every single scene…
    i am more of a video and authoring guy, so please be gentle 🙂
    kind regards,
    m.
    Willie Toth replied 19 years, 9 months ago 2 Members · 6 Replies
  • Willie Toth
    December 18, 2006 at 12:00 pm
    Try the “NORMALIZE” filter … Go to EFFECTS > AMPLITUDE > NORMALIZE … This filter will cut the peaks … I would set it to match your LOWEST volume … Once you have everything normalized you can then readjust the gain on the clip to where you would like … I think this may cure a lot of your problem but you may have to highlight and tweak sections … Personally speaking I don’t feel a “one click fix” is really the best way to go in most cases sometimes you just have to but the time in to make it right … I do hope the normalize does the job for you …. WILLIE
  • Nils Pokel
    December 18, 2006 at 3:28 pm
    thanks willie,
    thing is i tried it just the other way around – normalizing to the level i want the final clip to have. this resulted in some sections still being quite low leveled because the effect takes the peak levels of the ‘loudest’ sections as a reference. peaks (‘spikes’ if you like) in some sequences resulted in the same problem, which is why i applied a hard limiting effect beforehand. does this make sense?
  • Willie Toth
    December 18, 2006 at 3:48 pm
    The way you did it kind of compounds the problem … Hard limit default is a 6db boost so if you didn’t change that to zero you added 6db acrossed the board, this is why I suggested to make things match the lowest level using the normalizing filter … Try to go backwards and normalize to the lowest levels and then do another hard limit, (one of my favorite fliters by the way) … Becareful with your hard limit since you can really blow the dynamic’s all to heck but a second hard limit should be ok to do ………… WILLIE
  • Nils Pokel
    December 18, 2006 at 5:24 pm
    hmm, i tried your approach (or at least what i understood you ment) but it did not do the trick for me, in fact it did not make any difference at all…
    i did the following:
    normalize the whole wav down to -21 dB (lowest level thoughout whole file) and then normalize again to 0 dB. Result: nearly the original wave file.
    i guess this makes sense as the highest level is always the reference for the normalize action thoughout the whole file (or not?) and the proportions dont change when i apply “normalize” equally to the whole file. i would need something like a “individual normalize” instead of a “global” one.
    a screenshot of my file can be found here
  • Willie Toth
    December 18, 2006 at 5:31 pm
    OK, you can’t use normalize after you normalize to the lowest volume, you would need to use the Amplify to bring the gain up … If you highlight a low section you can work on just that section … When I get home tonight I will look at your file and give you some more direction if you haven’t got it by then ………. WILLIE
  • Willie Toth
    December 19, 2006 at 12:57 am
    Just highlight the parts you want to bring the gain up on and you will be good to go ………… WILLIE
