Activity Forums Adobe After Effects Expressions Audiokeys to slider?
  • Audiokeys to slider?
    Posted by Mikkel Aabenhuus on July 30, 2008 at 12:24 pm
    I am having problems combining a logos opacity to an audiotrack, and adding a slider so that opacity slowly goes to 100%
    …Im adding a slider expression control but cnat figure out what to combine it with?? 🙁
    Can anybody help?
    /Mikkel
    Thank you
    Mikkel Aabenhuus
    Chris Jepson replied 18 years, 1 month ago 2 Members · 1 Reply
  • Chris Jepson
    August 2, 2008 at 5:22 pm
    Hi Mikkel,
    what I think you need to do is;
    right click the audio> keyframe assistant, convert audio to key frames
    this will make a new layer which has a slider with values based on the audio. you can get rid of left+right channels, you only need ‘both channels.’
    now, go to your logos opacity, Alt click the stopwatch so you can enter an expression.
    Use the pick whip (it looks like a spiral) and pick the slider.
    this basically links opacity to audio.
    if for instance your opacity is too low (never over 20%)
    try adding something like +50; or *5; at the end of the expression.
    that will get the value of the slider, and add 50 or times 5.
    -chris
