Activity › Forums › Apple Final Cut Pro Legacy › AUDIO WON’T SHOW UP ON FCP7 (mntn lion)
Posted by Milton Ginsberg on June 22, 2013 at 7:28 pmimporting quicktime film clip into fcp7 (via mpeg stream, handbrake off of dvd off of tv)
audio wont import with it
though it WILL import into fcpx, qwicktime player ???
How do I do solve this?Milton Ginsberg replied 13 years, 2 months ago 4 Members · 7 Replies -
Shane Ross
June 23, 2013 at 6:25 amConverted to what format? And what compression type and frequency is the audio?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Rafael Amador
June 23, 2013 at 11:16 am[Milton Ginsberg] “importing quicktime film clip into fcp7 (via mpeg stream, handbrake off of dvd off of tv)audio wont import with it “
Open the file in QT or MPGStreamclip and see if the audio is MP2 (MPG-1/Layer2).
In that case FC can not read the audio.
Convert the DVD files to something with PCM audio (48Khz, 16 bits).
rafael -
Milton Ginsberg
June 23, 2013 at 2:38 pmThank you for trying to help, guys…
This is what MPEGStream shows me the characteristics are
which I want
and which I can’t import into fcp7Video Tracks:
Apple ProRes 422, 1280 × 720, 29.97 fps, 61.45 MbpsAudio Tracks:
16-bit Big Endian stereo, 48 kHz, 1.54 Mbps(no problem fcpx, but if i make an .mov in fcpx and import into fcp7
still won’t read audio???) -
Rafael Amador
June 23, 2013 at 3:05 pm[Milton Ginsberg] “Video Tracks:
16-bit Big Endian stereo, 48 kHz, 1.54 Mbps”
That seems OK.[Milton Ginsberg] “(no problem fcpx, but if i make an .mov in fcpx and import into fcp7
still won’t read audio???)”
The only way to know it, is to try.
Export a short clip and see what hapens.
rafael -
Mark Suszko
June 24, 2013 at 2:00 pmDumb question, but can you post a screenshot of your sequence settings and video/audio settings?
Milton Ginsberg
June 24, 2013 at 2:39 pmThanks everyone, problem solved. I took the audio into compressor and made
a quicktime audio file out of it and laid it in timeline. But thanks for all your interest. COW far and away the best place for editing help.
