Activity › Forums › AJA Video Systems › Audio without video
  • Audio without video
    Posted by David Perry on January 27, 2008 at 5:15 pm
    Is it possible to use the IO HD as a stand alone audio device without video? Sometimes I record concerts without video and it would allow me to use hte IO HD firewire interface into my Mac Book Pro.
    David Perry
    David Perry replied 18 years, 7 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    January 28, 2008 at 6:07 pm
    Are you going to record in FCP? i haven’t tried audio only with the ioHD yet but sometimes FCP likes to see a video signal even if you aren’t recording it. ANy video signal will do such as a DVD player or camera. As long as you a re feeding video to it, it won’t matter what it is. Now, that might not be true anymore but it’s the way it used to be.
    Jeremy
  • Carsten Orlt
    January 28, 2008 at 10:40 pm
    Best to use the ioHD with Soundtrack for audio only.
    Then again the latency is quite big while monitoring.
    It works but I haven’t really put it through its paces yet.
    I needed to record a quick VO but the delay drove me mad so I switch to the internal audio in/out of my powerbook for the time being.
    So yes it works audio only, but you may have to figure out a good workflow first.
    Carsten
  • David Perry
    February 19, 2008 at 12:16 pm
    Thank you all,
    I finally did get it to work as a stand alone firewire interface with Logic 8. It took some manipulation but I got 8 channels of AES working. Now I will try the 4 channels of line inputs to hear the quality of the converters.
    David Perry
    Carmen Productions
