Activity › Forums › Adobe Audition › Audio/ volume help
  • Audio/ volume help
    Posted by Tony Bartolucci on December 16, 2005 at 2:09 am
    I’m using adobe premiere to edit some footage shot with a sony vx2000, the audio level on the tape turned out a bit lower than I expected so I am going to use audition to boost up the levels. What is the best way to export the audio out of premiere, and what steps should I take to make the audio sound better using adobe audition or sony’s sound forge?
    Willie Toth replied 20 years, 9 months ago 2 Members · 4 Replies
  • Tony Bartolucci
    December 16, 2005 at 2:36 am
    After reading some of the other thread I decieded I should post some more details, this was a presentation that I recorded with my vx2000 using only the standard mic that comes with the vx2000. So it is all vocals/speech that i’m trying to make sound better, if need be I can email a short audio clip 🙂 I’m really really new to audition and dont really know where to start….
  • Willie Toth
    December 16, 2005 at 3:41 am
    Jack,
    Just go to EXPORT > AUDIO in Pre Pro … Once you do that open Audition and on the edit side go to FILE then open the audio clip that you exported from Pre Pro … There are several differnt ways to boost the audio, one is to simply go to EFFECTS > AMPLITUDE > AMPLIFY/FADE and boost the audio by however many DB you need … You can also use the NORMALIZE, or HARDLIMIT feature in the same tab … If you would like to send me a minute or so sample I can see what the best way for you to go is … E-mail to loganonestudio@aol.com ……… WILLIE
  • Tony Bartolucci
    December 16, 2005 at 4:48 am
    Ive sent you an email…Thanks
  • Willie Toth
    December 16, 2005 at 2:49 pm
    Jack,
    Here is the big problem from the get go … Hiss in spades … I have E-mailed you 2 MP 3’s just increasing the audio by 6 db and then doing a hard limit which brings the volume of the voices closer together … The other I did all of the above then used to hiss removal feature in the noise reduction tab …
    To amplify … EFFECTS > AMPLITUDE > AMPLIFY/FADE > 6 db
    BOOST
    To Hard Limit … EFFECTS > AMPLITUDE > AMPLIFY/FADE > HARD
    LIMIT …
    Settings …
    MAX AMP -1 db
    BOOST BY 6 db
    LOOK AHEAD 20 ms
    RELEASE TIME 100 ms
    Hiss Removal … EFFECTS > NOISE REDUCTION > HISS REDUCTION
    Settings …
    STANDARD HISS REDUCTION
    NOISE FLOOR + 30.76
    LEFT CURSOR 357.42 HZ -53.89 db
    RIGHT CURSOR 24000 HZ -117.23
    You will need to pull another cursor point from the left side by left clicking on the white cursor point and dragging a new point to … 8167.97 HZ -47.79 db
    This will give you better audio but there will always be hiss in it … The problem with taking the remaining hiss out with noise reduction is that you get digitizing or what I fondly refer to as the “rain barrel effect” and it is UGGGLLYY!!! Good luck just write if you have any other problems ……….. WILLIE
