Activity › Forums › Avid Media Composer › Audio Video sync 8 track limitation?
  • Audio Video sync 8 track limitation?
    Posted by Ben Mccarthy on January 29, 2010 at 1:50 am
    Software: Avid Media Composer version 3.13
    Hardware: Avid Mojo SDI
    We have a project where on set there are three digibeta cameras and two audio operators capturing data on to SD memory sticks.
    The audio is also captured to tape (1-4 track)
    What I want to be able to do is group a set of video clips with audio clips which both have the time of day time code.
    For example:
    CAM A: SCENEWORK 1 (V1 A1-4)
    CAM B: SCENEWORK 1 (V1 A1-4)
    CAM C: SCENEWORK 1 (V1 A1-4)
    AUDIO A: (A1-8)
    AUDIO B: (A1-8)
    TIME OF DAY TIMECODE of all clips are running parallel to one another (the camera operators all button on/off at different times, same with the audio)
    I want the group to contain 3 video tracks and 16 Audio tracks, but what I end up with is 3 video tracks and 8 Audio tracks
    Is this a limitation of the software?
    The other way around it is to lay everything onto a timeline and manually sync video/audio, but I’d prefer not to do this with the amount of footage I have to capture and sort for the editors.
    TIA, much appreciated
    Ben Mccarthy replied 16 years, 8 months ago 3 Members · 3 Replies
  • Job Ter burg
    January 29, 2010 at 9:16 am
    Not sure and cannot test at this time, but laying it in a timeline should be easy if you use AutoSequence on each source.
  • Michael Phillips
    January 29, 2010 at 9:19 pm
    You can make your first edit in the timeline all the audio tracks – or perhas use “audio follow video” for the 4 sync tracks to the video and just lay down audio onlu 1-8 to sequence tracks 5-13.
    Michael
    Michael Phillips
  • Ben Mccarthy
    January 31, 2010 at 12:46 am
    Great, thanks for the helpful replies
