Activity Forums Apple Final Cut Pro Legacy Audio & Video not in sync after export
  • Audio & Video not in sync after export
    Posted by Rawad Rhayem on September 14, 2012 at 1:03 pm
    i am using final cut pro 6.06 and i have two sequences that are totally in sync but every time i export them i get a delay in audio. I export using quicktime settings and i’ve done it over 100 times before but this time is not working. i deleted the audio render files and copied the sequence to a new sequence and still not working. Anyone had this issue before and how did you solve it?
    Chris Tompkins replied 14 years ago 2 Members · 1 Reply
  • Chris Tompkins
    September 14, 2012 at 3:21 pm
    What are you exporting to?
    What are you playing the file off of?
    A 10bit uncompressed HD file for example, will not play well off a single drive, you could experience lag in that case.
    Chris Tompkins
    Video Atlanta LLC
