Audio Very Low..
Posted by Bernard Ageeb on September 20, 2013 at 9:35 pmHi was recording a speaker with the wireless going into my Zoom H4n then out to my Canon 7d. The card filled up and i didn’t know but i could still hear audio with the headphone. The 7d audio is very very low. How can i increase the audio so i can finish my project? Thanks for your help in advance.
Bernard Ageeb replied 12 years, 11 months ago 5 Members · 12 Replies -
Peter Groom
September 21, 2013 at 11:23 amwhy cant you just sync up the audio from your zoom in your edit system.
PeterPost Production Dubbing Mixer
Bernard Ageeb
September 21, 2013 at 12:25 pmHi Peter,
the audio on the 7d is very very low and it will need havy boosting or something to get the audio level up. -
John Fishback
September 21, 2013 at 1:38 pmPeter, I think he meant the Zoom’s SD card filled up. To boost your levels you need to do that in an audio app or your nle. Depending on how low the levels are you may have to do a couple of passes by raising the level, exporting the audio file, reimporting and then raising levels again until you have enough level. Understand that all the noise in the signal will also be increased. You can remove some of that noise with an app like Izotope RX. You could also try playing the Zoom and taking its output into a preamp which you use to raise the levels. You’d record that raised signal with your nle or an audio app or second Zoom.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Bernard Ageeb
September 21, 2013 at 2:26 pmHi John,
Yes, the SD card stop recording and the line out from the zoom into the Canon 7d .The audio on the Canon SD card is what I need fixed. I try raising the audio and each time the noise is getting louder. -
Peter Groom
September 21, 2013 at 3:24 pmHI
yes, sorry Id not grasped that.Boosting a poor signal to noise recording will inevitably increase the bg noise as your recording is too near the noise floor.
why dont you post a short sample so we can hera the problem and seeif we can help with a fix.
Richard Crowley
September 22, 2013 at 3:59 amI heard 9 minutes and 19 seconds of moderate level hiss and NO signal at all. It is not at all clear what you want to do with this? There is no detectable signal here that I could detect.
Bernard Ageeb
September 22, 2013 at 10:43 amHi Richard,
Thanks for checking it out. I believe the cable which camee out of the zoom h4n into my canon 7d is bad or was not not in all the way. That is why i have no signal.Bernard
Peter Groom
September 22, 2013 at 6:39 pmThats not low level audio.
its no level audio.
Nothing to salvage here.
