Activity Forums Adobe Premiere Pro Audio Transition
  • Audio Transition
    Posted by Gurmeet Singh on January 13, 2014 at 8:45 pm
    I have a sequence with video footage on Video 1 layer. 4 Audio tracks that have a cut in the same place. I would like to know how I can apply a audio transition to all Audio layers at once, as the cut is in the same place. I would like to save time applying the audio transition to all audio players manually to each layer.
    Gurmeet
    Ivan Myles replied 12 years, 7 months ago 3 Members · 3 Replies
  • Paul Neumann
    January 13, 2014 at 9:18 pm
    Make sure all the tracks are targeted then select one of the cuts and shift+select the rest of the cuts and add your transition. Then just arrow down should move the playhead to the next edit with all of the tracks (edits) still selected. Rinse. Repeat.
  • Gurmeet Singh
    January 14, 2014 at 8:05 pm
    Thanks for your help. But I couldn’t get it to work. Are there any videos online?
    Gurmeet
    Gurmeet
  • Ivan Myles
    January 14, 2014 at 8:16 pm
    You could create an audio submix track, route the four tracks to the submix track (in the Audio Mixer panel), and then apply the transition to the submix or keyframe the volume of the submix as required.
