Activity Forums Adobe Premiere Pro Audio track problem
  • Audio track problem
    Posted by Gary Linzer on April 28, 2008 at 2:37 pm
    I set a number of audio keyframes and didn’t realize they were set as track volume keyframes not as click volume keyframes. my problem now is if I edit the video the keyframes that I set on the track volume don’t move with the video edits. So my question is, can I copy and paste the volume keyframes to the individual clips so I don’t have to reset all the keyframes I set on the track volume. Hope this makes sense. Thanks Gary
    Randy Mcwilson replied 18 years, 4 months ago 2 Members · 1 Reply
  • Randy Mcwilson
    April 30, 2008 at 11:35 pm
    The only 2 ways around this (kind of) that I know of would be to:
    1. Turn off all OTHER audio layers except for the one in question
    2. Set your work area bar over all of the affected audio in that track
    3. Do a File-Export-Audio of just that area
    4. Bring that exported audio (which now has all of your keyframed audio) back into your timeline and replace the old one, or put it into another track and then just mute the original track
    5. You may have to go along and cut it up and then link the sections to the various video clips.
    or
    Nest that audio track by itself into a sequence and then drag that sequences audio into your current sequence.
    Eternity…don’t miss it for the world.
