Activity Forums Adobe Premiere Pro Audio Track Issue (Premiere Pro Newbie)
  • Audio Track Issue (Premiere Pro Newbie)
    Posted by Scott Rosenkrantz on March 13, 2014 at 6:49 pm
    I messed up on a complicated shoot and ended up mixing two lavs into one mono track such that when listening to the audio in A1, one speaker’s voice is in the left headphone and the other is in the right. Is there a way to break the mono mix back into two component tracks in Premiere Pro CC? If not, where is the setting to center the mono mix?
    Any help is appreciated, even if you direct me to another post with the same issue on Creative Cow. Thanks!
    Scott Rosenkrantz replied 12 years, 6 months ago 2 Members · 2 Replies
  • Vince Becquiot
    March 13, 2014 at 7:40 pm
    Hi Scott,
    You can select all your tracks in the project panel, choose Modify > Audio channels and set them to mono.
    Alternatively, you can use the full left / fill right effect on your clips (fill left meaning that it sends the left channel equally to the right)
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Scott Rosenkrantz
    March 13, 2014 at 8:57 pm
    Perfect. Thank you, Vince!
