Activity Forums Adobe Premiere Pro Audio Track has no voloume
  • Audio Track has no voloume
    Posted by Robert William on March 20, 2009 at 6:52 pm
    I’m having a trouble, i converted several mp3s into wma format with 320 kpbs. Some of them when putting into audio timeline play in adobe and some of them don’t. I dont know whats going on?
    Eddie Lotter replied 17 years, 6 months ago 3 Members · 2 Replies
  • Remington Markham
    March 21, 2009 at 3:28 am
    You may want to check your actually audio track on the time line. On the left hand side of the track there is a little box you can check to turn audio tracks on and off. If that is not the case, click the file in your library and click play at the top of the library panel. If you do not here sound it is most likely an error from importing or converting. Have you played the audio in other programs without issues?
  • Eddie Lotter
    March 26, 2009 at 4:38 pm
    It would be better to convert to WAV format than WMA.
    You will also find links to many free tutorials in the PremiereProPedia that will quickly show you how things are done in Premiere Pro.
    Cheers
    Eddie
