Activity Forums Adobe Premiere Pro Audio track expansion or collapse
  • Audio track expansion or collapse
    Posted by Aj Vonwolfe on March 10, 2014 at 9:50 pm
    Is there a way to expand or collapse track height to all the audio tracks at once in PR CS6?
    I used to be able to do this in FCP7 with the key command Shift T?
    AJ VonWolfe
    Media Creator
    Beverton, OR
    “Imagination is more important than knowledge.”
    -Albert Einstein
    Dustin Straube replied 10 years, 11 months ago 2 Members · 2 Replies
  • Aj Vonwolfe
    March 10, 2014 at 10:36 pm
    I found it. Its deep in the keyboard shortcuts preferences. Under “Panels/Timeline panels/ audio track height.
    Not the best method but better than I had. I created the keyboard short cut shift T to expand, and shift ctrl T to collapse. However, I still need to hit the key command several time to get the track to the height I’d like.
    AJ VonWolfe
    Media Creator
    Beverton, OR
    -Albert Einstein
  • Dustin Straube
    October 29, 2015 at 3:48 pm
    You can also hold shift while scrolling up or down on your mouse. This will achieve essentially the same result.
    Dustin Emerson Straube
    dustin.straube@gmail.com
