Activity › Forums › Avid Media Composer › Audio track assignments not sticking with XDCAM footage
  • Audio track assignments not sticking with XDCAM footage
    Posted by Jared Flynn on March 30, 2010 at 1:48 pm
    Hi there,
    Our editor is working with some XDCAM footage (shot both on the EX3 and PDW-700) and we’ve run into some problems. We are trying to create track assignments within our sequences so we can conform them to our delivery specs ahead of time (leaving ch1 & ch2 open for narration, ch3 & ch4 for synch sound, etc etc).
    What seems to be happening, though, is that the assignments we define work for the first clip we cut into the sequence, after which the assignments reset to whatever the original order happened to be coming from the source.
    For the moment we’ve resolved to just let Avid do what it wants with the track assignments for the sake of consistency (so we can re-order them later) but that puts a serious kink in our workflow. Has this happened to anyone else? Is there a fix?
    Any help would be greatly appreciated!
    Thanks very much,
    Jared Flynn
    Motion Graphics Designer / Lead AE
    Lone Wolf Documentary Group
    Ed Cilley replied 16 years, 6 months ago 2 Members · 1 Reply
  • Ed Cilley
    March 31, 2010 at 5:47 pm
    [Jared Flynn] “he assignments reset to whatever the original order happened to be coming from the source.”
    So if I understand, you have a timeline with mulitple tracks of audio (1-4) and source footage with 4 channels. You want the configuration something like…
    Source>Timeline
    A3>A1
    A4>A2
    A1>A3
    A2>A4
    And each time you load a clip in the source window, it defaults back to
    A1>A1
    A2>A2, etc.
    Avid will look at each track and see which are activated. If tracks A1, A2, A7 & A8 are activated in the timeline, the clip will load as follows…
    A1>A1
    A2>A2
    A3>A7
    A4>A8
    I don’t know of a way around that.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
