Activity › Forums › Adobe Premiere Pro › Audio Time Units out of sync when I move tracks
  • Audio Time Units out of sync when I move tracks
    Posted by Abe Marks on August 10, 2010 at 12:25 am
    Greetings,
    I’ll start by saying I have searched high and low and found no info regarding this issue.
    I’m working in Premiere Pro CS4 editing an interview with 3 different audio tracks (Mic1, Mic2, Boom)
    The audio from each camera was slightly off causing a slight echo, so I enabled Show Audio Time Units, unlinked my audio tracks, and moved only the audio untill it was in sync with no echo, plays back perfectly.
    The problem happens, when I try to do pretty much anything, move the clips, drag everything to a new timeline, make a cut, all of these actions cause my audio to jump back to the original sync, causing the unwanted echo to return.
    I’ve tried toggling Sync Lock, Re-linking my video/audio, leaving the audio unlinked, grouping everything, but the same thing ALWAYS happens and it is very frustrating.
    Any help would be greatly appreciated,
    Thanks.
    -Long time Reader first time Poster.
    Michael Lorushe replied 16 years, 1 month ago 2 Members · 1 Reply
  • Michael Lorushe
    August 11, 2010 at 5:19 pm
    Not sure why that’s happening.
    Maybe try clipping each audio track where you want each to start, export one each separately and re-import them. Audio/video sync problems are no stranger to Premiere.
    Michael Folorunsho – Videographer & Editor
    http://www.mikedoesmedia.com
