Activity › Forums › Apple Final Cut Pro Legacy › Audio Synching from Canon 7D
  • Audio Synching from Canon 7D
    Posted by Sean Kapleton on January 8, 2010 at 12:56 am
    Hello
    I have just been handed a drive of Canon 7D footage as well .WAV files. I am batch processing them in compressor converting the footage to ProRes HQ 23.98 utilizing a cluster and thus all cores of this newer MacPro station.
    I wanted to know how to go about properly syncing the .WAV files to these transcoded clips.
    Any help and advice on this workflow would be greatly appreciated.
    notes from the sound guy were as follows:
    track audio recorded on a 702T HDD – transfered via data wrangler.
    Track 1 = lav mic
    Track 2 = boom mic
    13 files in total – #13 is 1k reference tone.
    No room tone as it was a recording studio so very quiet.
    Audio was running majority of the shoot even if cameras were not.
    sync via Digital slate with Time of Day T/C taken from master audio. Slate clap at beginning of take.
    24Bits
    48K
    23.97ND
    .WAV files
    John Fishback replied 16 years, 8 months ago 2 Members · 1 Reply
  • John Fishback
    January 9, 2010 at 10:41 pm
    As the audio will be longer than the video I’d first layout the audio on a timeline set so its timecode starts with your first TOD time. Then lay in the video clips at the timecode indicated by their slates. Hopefully everything remains in sync. Be sure your timeline setting matches your video. Use the appropriate Easy Setup.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
