Activity Forums Apple Final Cut Pro Legacy Audio Sync problems?
  • Audio Sync problems?
    Posted by Joseph Farris on August 31, 2005 at 1:04 pm
    I’m having some bad audio sync issues. The project was shot on a panasonic varicam at 24 fps. I have tried capturing with the kona 720/23.98 dvcprohd setting and audio seems to be off quite a bit, more than just a few frames. When I capture at the kona 720/59.94 dvcprohd setting audio seems to be off by about 4-6 frames. I have been capturing 30 min clips, I’m not sure if that makes a difference. What is the best setting for capturing varicam footage at 24 fps. How do I make sure the non- flagged frames are discarded? Thanks.
    G5 Dual 2.3
    3.5GD Ram
    500GB Firewire 800
    Kona 2 Card
    Final Cut 5
    Latest drivers
    Joseph Farris
    Director of Photography
    Visions of Light, Inc.
    Office: 312-829-8244
    Pager: 800.808.8244
    Mobile: 630.306.8244
    Fax: 630.690.7678
    http://www.visionsoflightinc.com
    joe@visionsoflightinc.com
    Joseph Farris replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
