Activity Forums Apple Final Cut Pro Legacy Audio sync problems exporting to .mov with only one sequence
  • Audio sync problems exporting to .mov with only one sequence
    Posted by Elizabeth Bridenstine on October 21, 2009 at 8:55 pm
    I have a project that is HDV 1080i60. There are multiple sequences. All sequences are exporting without any sync problems besides footage of one person. Any sequence that I open and use this person’s interview footage in, there are problems.
    I export as a .mov. Compression is H.264, frame rate 29.97. Dimension is 640×360.
    When I click, File, Export, Using Quick Time Conversion, the marker in the problem sequence automatically moves farther down the timeline and once exported the .mov audio and video do not match. I trashed my preferences but the problem is still there.
    Any help would be greatly appreciated.
    Elizabeth Bridenstine replied 16 years, 10 months ago 2 Members · 2 Replies
  • John Fishback
    October 21, 2009 at 9:21 pm
    I have no idea why this is happening. However, try Export to self-contained, Current Settings (do NOT recompress frames) – do not use QT Conversion. Open the file in QT to check sync. If it’s good, import that file into Compressor and make your H.264 file. If sync isn’t good, hopefully someone else will have another idea.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Elizabeth Bridenstine
    October 22, 2009 at 2:43 pm
    Hello John,
    Your suggestion worked, thank you so much! I exported as self-contained movie and there were no sync problems. I then just exported in quicktime as a .mov with the proper settings.
    Thanks again,
    Elizabeth
