Audio Sync Problems
Hello all!
Earlier today I exported an OMF from Final Cut Pro to mix in Digital Performer. After exporting the final mix from Digital Performer, I brought it back into Final Cut Pro. The audio gradually got more and more out of sync. I did a series of tests with different fps settings in Digital Performer, but the problem remained. I then tried exporting the audio to an AIFF (stereo mix) from FCP and bringing it directly back into the project, and the same problem occurred. It kept happening even when I exported the footage as an “audio only” quicktime movie using “current settings”.
Does anyone have any idea what is going on? Below are the technical details of my system.
FCP Sequence Preset:
1440 x 1080 29.97 HDV 1080i60Footage Capture Settings:
1440 x 1080 29.97 HDV 1080i60Camera Used:
Sony V1U in HDV mode at 24pComputer Info:
Final Cut Pro 6.0.6
Digital Performer 6.0.2
OSX 10.5.6
2 x 2.8 GHz Quad-Core Intel
4GB 800MHz
