Audio Sync Problem – Sampling Issue?
Hello,
I recorded a live event (speaker’s panel) where the audio was recorded directly out of the PA system, completely separate from the video track.
When I brought the video file and the audio WAV together in FCP6, they don’t exactly sync. In fact, the audio is slightly longer than the video track. For example, if I sync them up at the beginning of the video, by an hour in, the audio is more than 10 seconds behind the lips in the video.
My theory is it has to do with a sampling problem. Unfortunately, we made a mistake and sampled the audio at 44.1k and the video at 48k.
Short of changing the speed of the audio track in FCP to 100.5% or something, is there a solution? For example, is there a program that will change the sampling of the audio track from 44.1 to 48k?
What is it, and where can I get it?
Steve
