Activity Forums Apple Final Cut Pro Legacy audio sync noob question
  • audio sync noob question
    Posted by Gordon neil Allen on October 5, 2011 at 11:28 pm
    Hi, a workflow question regarding audio sync.
    On this shoot, a lot of the time there were two mics: one to the camera, one to a separate recorder.
    It is more advisable to sync all mics, then edit?
    Or edit first, then sync the 2nd audio source afterwards?
    Thomas Morter-laing replied 14 years, 11 months ago 2 Members · 1 Reply
  • Thomas Morter-laing
    October 6, 2011 at 8:07 am
    I would sync the mic first, that way it will all be there when you start moving bits around and cutting bits off- just make sure every time you cut a clip and move it you keep the off camera audio in sync!
    A better alternative if your budget permits would perhaps be pluraleyes: https://www.singularsoftware.com/pluraleyes.html
    Great bit of software syncs audio for you- great if you have lots of clips!
    Hope that all helps a little 🙂
    Tom Morter-Laing
    Freelance Editor,
    Certified Apple Product Proffessional, 2010
    http://www.depictproductions.co.uk
    Sony Z5, with Rode NTG2.
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
