Activity › Forums › Apple Final Cut Pro › Audio Sync Issues when exporting roles as separate track quicktime movie
  • Audio Sync Issues when exporting roles as separate track quicktime movie
    Posted by James Bayliss-smith on May 1, 2013 at 10:29 am
    I’m trying to export an interview with two distinct tracks of sound (lapel mic and radio mic). I do this all the time using roles exported as “Roles as multitrack quicktime movie”
    This time however we had some issues with the audio from the camera so I took some audio from the other camera (we were shooting a two camera interview) and synced it up with the problematic audio.
    The ‘new’ audio I synced precisely using option-> to nudge it to perfection I then assigned it a distinct ‘role’ so I could give the editor a choice between the two tracks. I exported using “Roles as multitrack quicktime movie” and assigned the two distinct track as mono. The resulting file has the two tracks out of sync when played back afterwards. If I export as Master File without roles the two tracks are mixed together but no sync issues.
    Am I doing something wrong or is this a bug?
    James Bayliss-smith replied 13 years, 5 months ago 2 Members · 2 Replies
  • Kyle Bass
    May 1, 2013 at 7:24 pm
    Have you tried exporting them as WAV/AIFF files, separately, using roles?
  • James Bayliss-smith
    May 2, 2013 at 2:02 am
    [Kyle Bass] “Have you tried exporting them as WAV/AIFF files, separately, using roles?”
    No I haven’t but I need it as one file that I can compress in a program called Newscasteer that maintains the distinct audio tracks. I need an mp4 and compressor mixes the tracks together when compressing an mp4.
    I work in news so the editors that I send my footage to require distinct tracks
    Do you think this is a bug related top the fact I used subframe nudging of the audio track?
