Activity › Forums › Apple Final Cut Pro Legacy › Audio sync issue w 29.97 timeline
  • Audio sync issue w 29.97 timeline
    Posted by Monica Berg on April 14, 2010 at 4:42 pm
    Hello,
    I really need help with an audio sync issue. I found similar threads but none that match up to my problem.
    We received an audio mix and when I import it into Final Cut it is 20 frames longer than my video which results in the audio being out of sync after I drop it into my timeline.
    I tried using Soundtrack Pro to convert the audio from 16bit to 32bit Floating Point so that it matches the timeline audio format but that didn’t work.
    Does this sound familiar to anyone?
    Monica Berg replied 16 years, 5 months ago 3 Members · 4 Replies
  • John Fishback
    April 14, 2010 at 7:41 pm
    The audio needs to be 16 or 24bit (which doesn’t affect timing) and 48kHz sample rate (which can). Of course your problem could be related to other issues such as your program being cut in a 23.976 (23.98) timeline and the audio shop set at 24. It’s helpful to provide more background on your situation – what codec used, framerate, etc.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Monica Berg
    April 14, 2010 at 9:35 pm
    We figured it out. It seems the audio mixer had some sort of “audio delay” option enabled in Pro Tools. This caused the audio to be out of sync.
    Thank you for your help!
  • Michael Gissing
    April 15, 2010 at 1:21 am
    For your edification, 32 bit floating point is the internal processing rate of the FCP sequence and not the clip bit depth. As John Has said 16 or 24 bit 48Khz is best. Do not make clips at a higher bit depth than 24.
    FCP outputs 24 bit from the 32 bit float internal. Higher bit rates with floating point processing are used on audio to reduce distortion created in changing levels, EQ and dynamics processing.
  • Monica Berg
    April 15, 2010 at 3:46 pm
    I completely understand. Thank you very much.
