Activity Forums VEGAS Pro Audio Sync Issue Resolution
  • Audio Sync Issue Resolution
    Posted by Mark Davidson on December 29, 2012 at 7:47 pm
    I rendered out to the Vimeo recommended mp4 specs and when I played it back, the audio was out of sync on some of the events.
    Playback of mp4s by default on my computer is with QuickTime. When I right clicked on the mp4 file and opened in Windows Media Player, the file was in sync.
    Thought the info might help someone.
    I have the last build of Pro 11.
    Mark Davidson replied 13 years, 8 months ago 2 Members · 2 Replies
  • Jacob Murphy
    December 29, 2012 at 7:55 pm
    Although I don’t upload to vimeo, I believe it might be Vimeo’s fault for causing such a problem. Have you tested to upload it onto youtube as a test to see if it’s the website’s fault? I upload to youtube and personally, I never see any problem with syncing and when you said that it works on your computer and syncs just fine, then I personally believe again, that it’s Vimeo’s fault. But if I were you, upload it to youtube as a test and see if that works well.
    Hope this helped.
  • Mark Davidson
    December 29, 2012 at 9:18 pm
    Thanks, I should have been clearer. I noticed the out of sync behavior on my locally installed mp4. I had rendered it to Vimeo’s recommended settings and caught the sync issue before it was uploaded it to Vimeo.
    My point is that a lot of folks may be blaming Sony Vegas for sync issues when the issue is their media player. It’s usually the basics that trip most people up.
