Activity Forums Apple Final Cut Pro Legacy Audio Sync Issue – Different Frame Rates?
  • Audio Sync Issue – Different Frame Rates?
    Posted by Blake Burress on November 7, 2009 at 9:54 pm
    I shot a film on 16mm and I had them transfer it to ProRes 422 for editing. This is an important project so the more organized and stable the workflow the better. I tried messing around with the Merge Clips (by in-points) feature but for some reason the merged clip it makes is always one frame ahead on the sound, so I had to set my in point one frame ahead of the slate clap spike in order to sync the clips. I feel like I shouldn’t have to be doing that though. I went back and looked at my audio and found that the WAV files are running at 29fps while my footage is on a 23.98 timeline. Is this why it’s not lining up correctly? Should i re-export my audio files at 23.98?
    Thanks so much.
    Blake Burress replied 16 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
