Audio Stuttering on Capture Playback
So I recently installed a fresh new copy of Windows XP onto my internal 500gb Harddrive. I am working on Avid Media Composer v2.8. Previously I was running the same thing, only I was running XP on an external harddrive connected via SATA. Had no problems then. But in my current set up, I’ve just logged into avid and the problems have begun.
Via my firewire, I have my panasonic PV-DC152D. It’s a pretty old consumer camcorder, but I have used it before to capture footage without a single problem. The cable I am using has also been used previously, no problems.
My problem begins when I go into Capturing mode within Avid. Even before I capture, I get audio stuttering on playback of my DV tape. I tried capturing as well, to my external 750gb SATA drive with no luck. Well, it captured, but all the audio was stuttering. So the problem begins even before I capture, just on watching my footage.
My project sample rate is 32khz. Sample Bit Depth 16 Bit. I have tried selecting only one audio channel. I have tried turning off the video channel and only capture audio, both for one and two channels.
Here is where I am most confused. I get into Windows Movie Maker, capture, and everything is fine. Flawless audio. No Stuttering. If it weren’t for this I would assume it was my cable or something. But everything captured fine on Windows Movie Maker.
I have no other firewire units plugged in. I have no USB units plugged in. I have tried disabling virus software. I am running on bare minnimum. I guess I am mostly fed up because when I was running XP on my external, I never had this problem while capturing. But now the problem has just sort of popped up for no reason.
My System Specs:
Intel(R) Core(TM)2 Quad CPU @ 2.66GHz (4 CPUs), ~2.9GHz
4 Gigs of Ram
NVIDIA GeForce 8800 GTX
SoundBlaster Audigy SE
Windows XP
Media Composer 2.8If there is any other information that could possible help someone determine my problem, please let me know. I have come to my wits end on fixing the numerous problems I encounter while using Avid. Any help would be greatly appreciated. Thanks.
