Activity › Forums › Avid Media Composer › Audio Stretching
  • Audio Stretching
    Posted by Ben Mills on July 3, 2012 at 3:45 pm
    Hey,
    I’m curious to know if there is an effective way of slowing down and stretching audio without mixing down my audio at all?
    I have a clip shot at 100fps w/a 24fps TC and audio recorded with a 24fps TC too,
    I want to slow down the audio and stretch it to fit the duration of my 100fps shot.
    I understand I could cut the audio into a sequence, add filler, mix it down, then apply the TImeshift effect and stretch the audio to fit that way, but its so long winded and I dont want to be dealing with mixdowns.
    Any alternative suggestions?
    Many Thanks in advance!
    Stacy Lincoln replied 14 years, 3 months ago 2 Members · 1 Reply
  • Stacy Lincoln
    July 3, 2012 at 5:29 pm
    To my knowledge, Audiosuite is the only way to time compress audio. If I have to do this, I make an audio mixdown of the compressed track…so I can then tweak the audio levels (because if you adjust them after the compression, it unrenders…which is really annoying). I have never found another way to do this. Because of that, I make the original timeline my “work” timeline, duplicate that, and put the audio mixdown on the “final” timeline. That way, I always have the original audio timeline if I need to go back and fix it.
