Audio Static Issue
Hi all,
I am currently experiencing an audio issue with a premiere output of mine.
My initial audio tracks were not recorded correctly and have some obvious static behind them. By applying the DeNoiser audio effect, and completely reducing the ‘individual parameters’ db, I have removed the static which clears almost completely in my sequence (see video tut for reference – https://www.youtube.com/watch?v=LEk5R5BpdwE).However, after exporting the sequence to a final output, that static comes and goes throughout that same audio track.
So I need to know why the problem seems fixed within the sequence, but returns once exported to an mp4 output.Its for an important job so many thanks to anyone that can help!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
