Activity Forums Apple Final Cut Pro Audio Split Tracks in FCPX
  • Robin S. kurz
    October 15, 2014 at 6:55 pm
    Oh, and individual mono clips/channels can in fact be panned btw. It’d be very odd if you couldn’t.
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
  • Jeremy Garchow
    October 15, 2014 at 7:19 pm
    [Robin S. Kurz] “Oh, and individual mono clips/channels can in fact be panned btw. It’d be very odd if you couldn’t.”
    Panning is simply routing them to a channel.
    Here’s a file: 8104_2channel.mov.zip
    Here’s the output settings:
    What do you hear?
    Jeremy
  • Christy Smith
    October 15, 2014 at 8:59 pm
    Thank you both for your insights! The first way I tried was through roles and exporting as mono and multichannel. But I still was getting both dialog and music in stereo (my settings were the same as indicated in the above image).
    When I tried the panning technique, it failed as well. However, after trying again this afternoon with a new project, the panning worked! I had dialog in one ear, music in the other. I think the first audio clips I was using must have become corrupted with all my tinkering.
    At this point, I’m just glad I have a way to export this without the show company having an aneurism.
    Thanks again for your input!
  • Robin S. kurz
    October 16, 2014 at 7:29 am
    [Jeremy Garchow] “What do you hear?”
    Left and right separated. Only I have no idea why those settings would do that, since the exact same settings here do nothing other than play both centered, just as I said and had already tested. And it obviously isn’t working for her that way either. I even just did it again to be sure. Go figure.
    Your file shows a single audio track with two channels, each with left/right assignments. No idea how you’re getting that. Mine comes out (as I would expect) with two separate tracks, each with a simple “Mono” assignment. Apparently the same thing she is getting also.
    So, I guess for some bizarre reason we were both right.
  • Tim Moyle
    October 23, 2014 at 6:03 pm
    Trying to figure this out myself right now. I have two audio roles in my timeline, “Dialogue” and “Music”.
    I am exporting as Master File and selecting “Multitrack QuickTime Movie” for the “Roles as:” option. I assign each role as “Mono”. Exporting the file does not separate each role, they’re center-panned or not-separated or whatever the right term for “both roles play out of both ears in my headphones”
    In my timeline properties, under “Audio Channels” I have the options “Surround” and “Stereo”. I have tried both but I get the same result every time.
    So:
    1) Should I be using a different export setting? (I created a ProRes 422 Dual Mono setting in Compressor and imported it into FCPX, but I didn’t gte the “Roles as:” option when I went to export)
    2) How should I configure “Audio Channels” in the timeline properties?
    3) Is there anything else I could be missing?
  • Jeremy Garchow
    October 23, 2014 at 7:46 pm
    [Tim Moyle] “I am exporting as Master File and selecting “Multitrack QuickTime Movie” for the “Roles as:” option. I assign each role as “Mono”. Exporting the file does not separate each role, they’re center-panned or not-separated or whatever the right term for “both roles play out of both ears in my headphones””
    If you provide a dual mono (discreet channel) file, they will simply turn off what they don’t need.
    The easiest way to check the file is to simply reimport it to FCPX and have a look.
    Jeremy
  • Tim Moyle
    October 23, 2014 at 8:12 pm
    Sorry, I should have been clear. I need to provide a file with the dialogue coming out of one speaker and music coming out of another speaker. I’m afraid the person I’m making this for doesn’t have the technical know-how to turn off what they don’t need (he’s literally going to unplug a speaker to mute the music).
  • Tim Moyle
    October 23, 2014 at 8:14 pm
    I also can’t figure out how to export a dual mono file. The file defaults to whatever setting I specify in the timeline settings and my only options there are “Stereo” and “Surround”, neither of which seem to accomplish what I’m looking for.
  • Jeremy Garchow
    First, dupe your timeline and do this on a copy.
    Than pan all dialog left, pan all music right, and export a stereo file.
  • Tim Moyle
    October 23, 2014 at 8:16 pm
    I guess that’s my only option. Thanks for your help!
Page 2 of 4
