Activity Forums Apple Final Cut Pro Legacy audio speed changes won’t play from upgraded FCP project
  • audio speed changes won’t play from upgraded FCP project
    Posted by Andrew Dieringer on June 26, 2009 at 8:10 pm
    I’m flabbergasted! Audio speed change clip plays unrendered (with beep,beep, beep) in timeline but once rendered doesn’t play… Audio plays fine in viewer window EXCEPT between in and out of clips… WTF! This is from a project file from a few years ago…(FCP 4.5?) Tried to export a QT clip of this from the viewer window to re-import…worked once with the wrong frame rate…now not working with DV NTSC settings. Any takers? Thanks, ad
    Andrew Dieringer replied 17 years, 2 months ago 3 Members · 5 Replies
